Discussion topic: Headphones volume
This message was authored by: mrblueskyglass
Headphones volume
Hi
I added my Bluetooth headphones to Glass, but the volume is way too low and seems to be stuck. I can't increase it using the remote or the controls on the headphones themselves.
I've checked the settings but saw nothing obvious.
Anyone else run into the same problem or know of a fix?
This message was authored by: Mr+Flibbles+86
Re: Headphones volume
Avatar for mrblueskyglass
Thank you, although not necessary - turning Glass off and on again fixed it. Don't know why I didn't try that sooner.
Headphones working fine now 👍🏻
