Discussion topic: Fire stick on sky glass
Message posted on 05 Oct 2025 09:58 AM
We have just recently got the 2nd gen of sky glass and when I plug the fire stick in I am getting a black screen, does anyone know why? It works on other tvs just now sky glass.
thanks
Message posted on 05 Oct 2025 11:43 AM
Re: Fire stick on sky glass
Hi @Finlayson89 and welcome to the forum.
When I had a Gen 1 Glass I had a firestick connected to it without any issues. However the the firstick needed to be plugged into a separate mains power supply as Glass did not give it enough power. Also, make sure you have selected the correct HDMI input or you will get a blank screen.
Message posted on 05 Oct 2025 01:08 PM
Also your firestick may have been set to a certain screen resolution on your other tv
you may need to boot it on another tv and change screen resolution to automatic
