2
This discussion topic has been answered Discussion topic: Does a sky glass tv work on any WiFi router?
This message was authored by: Xerri
I have looked at the offers sky have atm and as normal new customers get better deals so I am looking to another provider
the new provider offers a asus ax3000 duel band router and 300mps for £30 would this router be ok for sky glass?
cheers
John
This message was authored by: Mark39 Answer
Re: Does a sky glass tv work on any WiFi router?
Glass should work ok with any broadband router. Mine works fine with a BTHub.
Hi @Xerri Yes, you can use any broadband provider or Router with Sky Glass or Stream.  The important thing is that you have a strong and stable signal.  300mps should be ample speed as the recommended minimum speeds for the streaming platform are
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
