Discussion topic: Discovery Channel Audio Delay
Message posted on 09 Jun 2024 12:29 PM
Hi, I have a SkyGlass TV and i have horrible audio delay on the discovery channel, the discovery plus app works fine but its just when i livestream the actual channel. All other channels are absolutely fine, could anyone please help me?
Message posted on 09 Jun 2024 01:49 PM
Re: Discovery Channel Audio Delay
@MarkJames66 wrote:Hi, I have a SkyGlass TV and i have horrible audio delay on the discovery channel, the discovery plus app works fine but its just when i livestream the actual channel. All other channels are absolutely fine, could anyone please help me?
This is the second post I've seen today with sync issue on discovery. Potentially a temporary app issue.
always worth pulling the plug on the tv for 10 minutes to see if that solves it though
Message posted on 16 Jun 2024 08:07 AM
Hi, I have the same issue. The audio on. Discovery Plus is out of sync when you access the channel from the Sky TV guide, but is fine if you access via the Discovery Plus app. Why would that be?
Message posted on 27 Jun 2024 06:45 PM
Same issue here it's infuriating and can't solve it
Message posted on 28 Aug 2024 12:44 PM
Hi, I am having exactly the same issue on discovery channel. If I changes channels then go back it corrects itself but the get dropouts and it goes out of sync again. Very annoying.
Message posted on 30 Aug 2024 08:31 PM
I only ever have sync issues in Discovery - usually the audio is about a second ahead of the visual, and that includes adverts. It's been like this for months, so there must be an issue with the channel.
Message posted on 30 Aug 2024 09:03 PM
I have exactly the same issue. I watch discovery he from the tv guide and the sound pops and the lip sync goes out. Sometimes it pops quite often.
I've spoken to sky about it this evening as I was annoyed. They went through the reset process and checks but all was fine. They even offered to replace the glass tv but I said no, it's not an issue with the tv it's an issue with the stream.
No other channel has this issue.
they reported they are looking into this and will hopefully resolve it soon. I told them I'd call back in a month and ask for a refund if it's still happening as I'm paying for a service I can't use.
Message posted on 24 Oct 2024 08:03 PM
Been happening on my sky glass for a while now too, really annoying and no way to fix it
Message posted on 25 Oct 2024 01:44 PM
Mine improved when I unplugged my network cable and run on WiFi. I have since plugged the network cable back in and it is worse than ever recently. Mine does exactly the same as above it makes a pop type sound and then goes out of sync. Each time it pops it goes further out of sync.
Message posted on 12 Nov 2024 12:00 PM
Exact same on my sky stream. Changed audio settings to numerous variations, no joy. It's only discovery channel.
Message posted on 15 Jan 2025 11:06 AM
Same here tried everything to stop it happening but every day the issue is there today it's especially bad within 30 seconds of changing channel to reset it it's back out of sync again really annoying almost to the point of stopping me watching the channel
Message posted on 15 Jan 2025 01:29 PM
It has recently gone worse on my Sky Glass - it isn't just Discovery channels that this happens with, but has now spread to the U& channels!
