Discussion topic: Despite resetting the entire system (WiFi and Sky Glass) channels are not playing
This message was authored by JohnR72 This message was authored by: JohnR72
Despite resetting the entire system (WiFi and Sky Glass) channels are not playing. Just a blue screen for minutes at a time. I'm paying good money for an unreliable service. WiFi speed is excellent. Connection is good too Sky Glass. Still nothing plays. Very hot and miss. Not good enough. Solutions?
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Despite resetting the entire system (WiFi and Sky Glass) channels are not playing
When you say resetting the system what exact steps were you taking?
Sky Stream and Sky Broadband customer
Also have you done a speed test from the TV itself to check the connection speed from the TV. You can do this via the Netflix app by going to Get Help and then Check your network. That will give you the downloads speed the glass is currently getting.
JohnR72
Turned everything off and back on and then performed a reset between Sky WiFi and Sky Glass. This should not need doing on a regular basis as I am now. But thanks for the prompt response.
JohnR72
The speed test via the Netflix app sounds interesting, I'll give it a go tomorrow. Thanks.
JohnR72
Have Run the Netflix network test a couple of times now and the speed reading comes in at between 14 and 15 mbps each time. My phone's WiFi check for my router comes in at over 100 mbps each time. The router is sat beside my Sky Glass. What the hell? I know Sky Glass needs over 30mbps to work properly. Why are the tv's internals so crappy?
Ok that seems strange if the router is right next to the TV.
Does it work better if you can connect it to the router via an Ethernet cable?
What router do you have? Is it a Sky Hub?
JohnR72
Hi, it's a max hub from Sky and doesn't come with an Ethernet cable unfortunately.
TBH id just phone and complain to Sky at this point. The fact you have a Sky glass and Sky Max Hub right next to each other and it's still not giving you the correct speed on your glass is just strange.
There could be a wierd setting to change or perhaps a fault on the TV, either way phoning Sky is probably the best thing to do at this point.
@JohnR72  Having it too near the TV can be an issue, it needs to be away from any form of interference as the TV can be the cause of interference.
JohnR72
Okay, thanks for letting me know. I'll move it away and see what happens.
This message was authored by Jporch316 This message was authored by: Jporch316
@JohnR72
The sky hub / router comes with a yellow ethernet cable in the box
You will need to disable WiFi in the glass settings if you plug the ethernet in
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
JohnR72
Cheers for the info.
This message was authored by GagaP This message was authored by: GagaP
Glass is rubbish good concept but poor service and doesn't work with some WiFi or Ethernet!Total waste of money for us and they won't budge so I'm going to speak to a lawyer about action as we can prove internet etc works fine! It's their internal network cards that can't always work! They scam you with BT as well as o ly offer part of the application u like that on the full app via BT customers.
