Discussion topic: Connection issues today
08 Jul 2024 01:53 PM
I am experiencing issues today. My TV is connected via WiFi. When I turned my TV on this morning it said I had no internet connection but other devices that use WiFi were all working fine and all three green lights were illuminated on the Openreach outlet.
I turned the TV and the Openreach outlet off at the mains, left them for several minutes and turned the power back on to both the TV and the Openreach outlet and the TV then connected.
All morning and upto now my TV is continually freezing and buffering. The picture also pixelates intermittently before returning back after several seconds. The picture will also disappear altogether and I then get a message saying 'Please wait for your programme to load' but it doesn't load and I then get a message saying 'There is a technical fault with this channel'. I end up having to change the channel and then change back to the original channel that I was watching but after doing that, the sound is now out of sync.
I have just turned the TV and the Openreach outlet off at the mains again, left them for several minutes and turned the power back on to both the TV and the Openreach outlet and the TV connected but the same issues described above are all still happening.
I pay Sky for Ultrafast 145 Mbps broadband but I have just done a speed check on Netflix and the connection speed was 7.8 Mbps.
Other than connecting with an ethernet cable and disabling the WiFi which I don’t think I should have to do, does anyone have any other suggestions on what I can do?
65" Sky Glass in Anthracite & 145 Mbps Ultrafast Broadband
09 Jul 2024 02:37 PM
Thanks for the information both @MarkGoldsmith and @Jporch316
I have not had any of the issues that I experienced since yesterday morning so I am hoping it was just a temporary glitch which has now rectified itself. I may fit an ethernet cable and disable my WiFi if it happens again and continues to happen but it means me routing the ethernet cable under the floor and up through my chimney breast as I would want it hidden 🤔
Thanks again.
