Discussion topic: Cleaning screen sky glass tv
Message posted on 12 Sep 2024 04:44 PM
Hi there, first time cleaning the screen on my sky glass tv using glass cleaner. Can I use a damp micro cloth to clean the screen, thank you.
Message posted on 12 Sep 2024 06:28 PM
Re: Cleaning screen sky glass tv
@Lovely+Joy wrote:Hi there, first time cleaning the screen on my sky glass tv using glass cleaner. Can I use a damp micro cloth to clean the screen, thank you.
It's not adviseable to use glass cleaner. The Sky Glass screen is not made of actual glass and using any form of chemical on it is likely to cause lasting irreversible damage.
A dry or very lightly damp (with water) microfibre cloth should only ever be used.
Message posted on 28 Nov 2024 09:01 PM
I've used glass cleaner to clean my sky glass tv for the first time. And have only just realised I shouldn't of done that. It looks ok right now and won't do it again is it like I have damaged the screen only doing this once
Message posted on 29 Nov 2024 11:15 AM
A TV screen should only be cleaned using a damp cloth then buffed dry and smear free with a soft micro fibre cloth. Never use chemicals or screen cleaners.
Thirty years in TV manufacturing 😉
