22 Jul 2023 03:22 PM
Hi am I ok to use a VESA extendable wall mount for my 65" sky glass tv? It says it takes weight up to 50kg. I am having a media unit built around it
22 Jul 2023 03:37 PM
@themission wrote:Hi am I ok to use a VESA extendable wall mount for my 65" sky glass tv? It says it takes weight up to 50kg. I am having a media unit built around it
As long as the wall mount is very firmly secured to a very solid wall then it should be OK. The 65" Glass is a heavy TV and I'm not sure I'd recommend swinging it about too much on the end of an extendable mount.
22 Jul 2023 03:49 PM
Posted by a Superuser, not a Sky employee. Find out more@themissionAs the 65"'s weight is 28Kg that should be fine, the important thing is the strength of the wall and the fixings to the wall.
