Discussion topic: BBC channels freeze and sound lags
This message was authored by: Laura145
Whenever we watch a BBC channel ( including BBC Scotland etc) after about 20m, the channel sounds cuts out for a second then starts again.
Re: BBC channels freeze and sound lags
@Laura145Try rebooting your Glass TV. To do this simply switch off your Glass at the plug socket and wait for a minute before switching it on again.  It will take about a minute to reboot.
If that doesn't help try refreshing the apps.  This takes a few hours but is done in the background so you can still use the TV.  You will find the App Refresh in Settings > System Management > Resets and updates > refresh apps (do NOT do a factory reset).  On the odd occasion I have done a refresh of the apps I do it at the end of the evening so they refresh overnight.
This message was authored by: Caroline01091
We have rebooted once at least but the problem persists. Internet speeds all good. We have had one replacement box..... what now?
