4
This discussion topic has been answered Discussion topic: As skipping not working on Sky Glass
This message was authored by: MC001
Hi. My subscription has ad skipping but when I try and fast forward it just takes me back to the same advert.
I have just changed to sky glass. Is there something I need to switch on?
ta
This message was authored by: Jporch316 Answer
Re: As skipping not working on Sky Glass
@MC001 wrote:
Thanks. I was on Sky Atlantic in demand and it didn't work for the Ads at the beginning and during the show.
Any help appreciated !
(the sky glass is new)
Try pulling the plug from the socket for a few minutes ..... this normally cures minor glitches. I have mine connected to a smart plug so I can use an app or alexa to power it down without leaving the comfort of my sofa ......
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
@MC001
Ad skipping works differently in different apps. Which app are you having difficulty with? See: https://www.sky.com/help/articles/ad-skipping-sky-glass
Obviously if your watching from start and catch up with the live broadcast or watching live you can't skip ahead any further.
MikeAlanR
Avatar for MC001
Avatar for MC001
thanks @Jporch316 it now works
go figure!
Answered - Go to Answer
