Discussion topic: wifi
This message was authored by: claude76
wifi
sky broadband is awful they should be paying me as watch youtube,netflix, prime etc it keeps buffering and on computer things load up so slowly like the old dial up, run sky test says everthing is ok i dont believe in these test of course they gonna say that. can i get out of this contract as not getting service paying for, but of course there tests state everything is ok this is so you cant get out of your contract.
Re: wifi
@claude76
