Discussion topic: wifi so bad
Message posted on 11 Aug 2025 12:00 AM
wifi so bad
Message posted on 11 Aug 2025 05:35 AM
Re: wifi so bad
@Emelia73
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Remember: Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won't receive additional or quicker support.
Message posted on 11 Aug 2025 07:08 AM
Re: wifi so bad
@Emelia73 As a user who is going to rely heavily on a Internet connection will advise you to THINK very carefully about your next option that you goto you require Home and Mobile fallover backup Broadband and ideally on a business connection with rapid response for down, and do hope that you have a GOOD mobile area connection!👌
