4
This discussion topic has been answered Discussion topic: wifi problem
This message was authored by: young+jack
wifi problem
just joined sky fibre 150. the wifi upstairs is not very good, would a wifi SE210 solve the problem
Avatar for young+jack
This message was authored by: young+jack Answer
Re: wifi problem
Re: wifi problem
@young+jack
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Re: wifi problem
That's the booster to match a Sky Broadband Hub: it won't work with a Max Hub.
Re: wifi problem
Many thanks
Re: wifi problem
  • Thank you , just got sky max big difference
