Discussion topic: wifi performance
This message was authored by: HollieMK
wifi performance
wifi performance is very poor. much worse thatn my last provider, so much so my daughter has ran out fo mobile data for the first time ever.  i continually have to turn my wifi off to access my apps on my phone.  some of the tvs in the house work and others dont
Re: wifi performance
@HollieMK
A poor signal is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
