Discussion topic: wifi password
This message was authored by: KennyS1
wifi password
I need my wifi password. It is not on the back of my sky hub and I cannot see it on my account anywhere. I have lost the card that came with the hub with these details on it?
Re: wifi password
@KennyS1
Are you sure it isn't printed on the hub itself as it should be if it came from Sky. Failing that are you able to login to your router to see what it is ?
Avatar for KennyS1
Re: wifi password
Hi
Deffo not printed on my sky streaming box. I don't know how to check online to get into the router ?
Many thanks
