Discussion topic: wifi not working
This message was authored by: daniellec04
wifi not working
my wifi just disconnected every device and said i have to log in to get to gateway settings? but i have no idea what the login is and i can't find it anywhere
Re: wifi not working
@daniellec04
The first thing to check is this link to see if there are any outages in your area as there are issues in the CM2 and CM3 areas at present it seems, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
