Discussion topic: wifi not working
This message was authored by: Val1948
wifi not working
wifi is either not working or slow
all lights were showing as green on the device before restart
all lights showing as green after the restart
weak signal, laggy service on all devices at home
Re: wifi not working
@Val1948
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Avatar for Val1948
Level 0 icon
seems it's now working on mobiles but not on tvs - showing poor connection to devices when running check on the app
