Discussion topic: wifi not working
This message was authored by: AnnetteG
wifi not working
I have an orange voice lught and my internet is not working what should do?
Re: wifi not working
@AnnetteG
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
