Discussion topic: wifi not working
This message was authored by: georgia41
wifi not working
my wifi has had issues the last two weeks and now it's completely not working i have unplugged it re plugged it. reset it etc, nothing is working.
Re: wifi not working
@georgia41
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
