Discussion topic: wifi not working
This message was authored by: neave2
wifi not working
wifi not working
Re: wifi not working
@neave2
Wifi or internet? Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
This should determine if there's an identified fault affecting multiple households.
