Discussion topic: wifi cut
Message posted on 06 Mar 2025 08:33 PM
wifi cut
wifi keeps cutting out. orange lights on box. Keeps happening multiple times a day for the last week
Message posted on 06 Mar 2025 08:35 PM
Re: wifi cut
@LisaE36
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
