1
This discussion topic has been answered Discussion topic: :((
This message was authored by: Maniek77
I haven't had internet access since this morning.
Re: :((
@Maniek77
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Re: :((
@Maniek77
