2
This discussion topic has been answered Discussion topic: the LOS light is solid red and it started after the heavy winds.
This message was authored by: Nisansala
the LOS light is solid red and it started after the heavy winds from yesterday. we are struggling without Internet.
please fox this as soon as possible.
thank you
Re: the LOS light is solid red and it started after the heavy winds.
@Nisansala
You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
@Nisansala
@Nisansala You need to call sky directly, the Forum is not sky Customer Service, possible one off the superuser's may do a connection, but calling would possibly be a quicker resolve for you!
