Discussion topic: sky mobile
This message was authored by: aids
sky mobile
hello im having problems with my wifi ill use apps like insta and snap and safari and everything is buffering and wont load properly its been doing this for days but the wifi checker says everything ok but its not and ive turned the wifi router off and on but still doesnt work, it works fine on youtube sometimes and works fine on some apps and others not so well
Re: sky mobile
@aids
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
