Discussion topic: sky max
Message posted on 20 Apr 2026 12:56 PM
sky max
I purchased sky max on the promise that I would not have black spots in my house. I have black spots in the rooms furthest away from my router including my bedroom. I understand you can provide pods based on the guarantee of now black spots and would like to request 2. I work from home and I currently not getting consistent WiFi in my office so I am having to work from the kitchen.
Message posted on 20 Apr 2026 12:59 PM
Re: sky max
@Riona12 You will need to call Sky to request the pods as the community has no way of knowing who you are from your post.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
