Discussion topic: sky max hub
Message posted on 08 Sep 2026 09:00 AM
sky max hub
Had a sky max hub delivered a couple of weeks ago and have had trouble with everything else since then. Alexa doesn't work properly anymore, tv has its moments. problems with doorbell and now I can't get my printer to work. As I am 86 years old I just cannot cope with it.
Message posted on 08 Sep 2026 11:26 AM
Re: sky max hub
With a white Max Hub you may need to reduce the wireless security level from WPA3-T to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
