Discussion topic: sky hub
This message was authored by: NightShade_01
sky hub
it wont log me in to the sky hub using 192.168.0.1.. ,,, i have tried reseting to factory settings it wont work
Re: sky hub
@NightShade_01 where is it failing at when you enter the username or the password, and whay sky Hub do you have? see the link below as an example to get to the sky Hub!
Find, change or reset your WiFi password | Sky Help | Sky.com | Sky Help | Sky.com
