Discussion topic: sky hub max port problem
Message posted on 01 Oct 2025 06:18 PM
I have a sky max hub, I want to forward ports but it doesn't work for me through the app because I can't fix it there until I can. It doesn't let me enter 192.168.0.1, how do I get there? Because in the old hub I did everything through 192.168.0.1
Is it possible to access 192.168.0.1 without the sky app?
Message posted on 01 Oct 2025 06:39 PM
Re: sky hub max port problem
@Abglanz NO sky Max app use only!
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
Message posted on 01 Oct 2025 06:56 PM
Thanks, then how to open the port? WIFI opens everything fine, if you want to use the cable then the ports do not open
Message posted on 01 Oct 2025 07:08 PM
@Abglanz See the link!
Message posted on 01 Oct 2025 07:59 PM
When i enter 192.168.0.1 into a browser to access my router it seems to flick to https://myrouter.io/
Message posted on 01 Oct 2025 08:01 PM - last edited: 01 Oct 2025 08:07 PM
@Abglanz try putting the http:// in front of the number? wont matter much there is not going to be much you can do, as before YOU NEED TO USE THE APP for anything that needs to be changed!
Everything you did with the old hub, then forget that it does not work with the sky Max hub, there is NO web interface as such, security to the device and operation of the device is NOT the same!
Link above explains, and look at the using advanced options for your port forwarding as explained in the help link!
Message posted on 01 Oct 2025 08:08 PM
I tried with and without http://, the app, there are few options, I need to web
Message posted on 01 Oct 2025 08:10 PM
@Abglanz You can only use the app and nothing else!!!!!!
