Discussion topic: -signal strengh
Message posted on 05 Oct 2025 05:55 PM
-signal strengh
The signal strength is not strong enough from the ps5 upstairs to the portal in the front room downstairs
Message posted on 05 Oct 2025 06:20 PM
Re: -signal strengh
@Zoe154 couple of choices first is to get a wifi extender which Sky will supply on request if you buy theur WiFi Max package. The second however is better if you wantvyo game which is to buy a powerline networking kit which uses your mains wiring to get thecdata to an upstairs bedroom.
Message posted on 05 Oct 2025 08:15 PM
Re: -signal strengh
@Zoe154 Were is the sky hub in all off this, each device uses the Internal wi-fi and not a PS5 to the Portal as a direct connection!
