Discussion topic: secon box not working
Message posted on 20 Jun 2026 08:58 PM
Upstair tv will not connect to sjy
Message posted on 20 Jun 2026 10:27 PM
Re: secon box not working
A poor signal in certain rooms can cause issues like this as this is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Message posted on 20 Jun 2026 11:25 PM
Make sure your main box is not dropping it's internet connection.
