Discussion topic: router setting
Message posted on 03 Jun 2024 09:15 PM
router setting
when i set up my new router , the setting were set up youing the web page on my pc, now i cant use the pc i have to use the app.
can this be changed back as i stuggle to see the small screen and way much prefer the large screen ov my desktop pc.
this should not be forced upon us this should be as it was.
please how do i remove this from the app back to my web page.
Message posted on 04 Jun 2024 11:38 AM
Re: router setting
You can't, this is how the new Sky hub is administered and so will be most ISPs routers in the near future. Could you not just increase the font size and/or use a screen magnifier on your mobile device? Realistically how often do you need to interact with your routers settings anyway? It should be a set once and forget job.
Message posted on 04 Jun 2024 06:01 PM
Re: router setting
when i instaeed the router it was all via the web interface, why cant they let us decide what we prefer i hate that we are forced by stupid people to do what we dont like or want to do.
i was very happy administrating the router via my web interface.
what do i do if i dont have a smart mobile as i have bought a lovely nokia 7110 mobile as all i use my phone for is calls and texts.
in the next week or so i wont have access to the app for any isp.
Message posted on 06 Jun 2024 10:41 AM
Re: router setting
If your internet needs are basic enough that you don't even have a smart phone then I don't see why you would even need to access your routers admin settings since its setup with the best default settings out of the box?
The only option I can think of is if you run the My Sky app in an emulator on PC using something like BlueStacks.
