Discussion topic: router login
This message was authored by: t-den
Message posted on 01 Sep 2026 05:34 PM
router login
when i try to log into my router , 192.168.0.1 it comes back with "Check if there is a typo in myrouter.io." anyone any ideas what this means
Find out more
Message posted on 01 Sep 2026 06:04 PM
Re: router login
If you have the white router then you need to use the MySky app:
https://www.sky.com/help/articles/access-your-sky-broadband-hub-settings
