Discussion topic: return of router
This message was authored by: APM19
return of router
You have sent me a retruns package for my router but no instructions and no pre paid label. What happens next
Re: return of router
@APM19
Rhere should be a label on the packaging so you just put the router inside of the packaging.
If there is no label then this link will help you to print the return label and return it via Royal Mail:
https://www.sky.com/help/articles/return-tv-broadband
Add a note inside with your account number and a list of equipment you have included.
Make sure you get and keep proof of posting when sending this off.
