Discussion topic: problem
Message posted on 27 Feb 2026 10:01 PM
problem
wifi not working
Message posted on 27 Feb 2026 10:16 PM
Re: problem
@NJCardeno What is not working with it, no wifi signal from the sky Hub?
Re: problem
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
