Discussion topic: problem connecting to network
This message was authored by: Stevie561
Wi fi and sky+HD box workkng properly. Have used WPS buttons, password and pin number but after a while TV shows there has been a problem connecting to the network please check your settungs and try again. Our unternet and phone are working
Re: problem connecting to network
Avatar for Stevie561
It's a Sky+HD trying to connect to a hub model SR203
@Stevie561 Take a look at the help info, may be that your HD+ is just getting old a tired now!
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
It was working fine until we had a new hub fitted
I'm just going to give up on it. Maybe go back to Virgin
@Stevie561 Not had an old box like that connected for at least 10 years now and when i did it was Ethernet connected to an old Q hub at the time!
As both boxes are close together I'll dig out an old ethernet cable if I can find out what one looks like
This message was authored by: Cavaqueen
No network connection, been like this since 6pm.
Apparently an outage EH6 area
I've plugged an ethernet cable into the hub and Sky+ box but still nothing. Do I have to do somethikng else to get them to connect?
@Stevie561 Link on post 4 will show it all, and selecting Ethernet i would assume!
It just says plug in the ethernet cable both ends and it should work, but it doesn't. I have tested the broadband online  and all is working but it is still not connecting. Who do I turn to next or should I just go back to virgin?
@Stevie561 Think you still have to go through all the connection process or switch wireless off and allow ethernet to do it all! My SR203 hub has 2 lights for the Ethernet port, do you see anything light up when you have both devices connected by a cable, dont see any lights on the old HD+ box so not sure if it has any!
Sky Q permanent connectivity - Basic checks | Sky Help | Sky.com | Sky Help | Sky.com
