Discussion topic: not getting guaranteed minimum speeds
Message posted on 06 Mar 2025 09:21 AM
Hi, I've been with Sky for a while now. Previously had Ultrafast broadband with speed checker (extra £10 per month) which checks I get the correct speed everyday. When checking on the Speedtest app on my phone (S23 ultra), I used to get a very steady download speed of 150mb/s, which is what I was paying for. I have not long upgraded to 900mb/s gigafast and had full fibre connected. The engineer who installed it and checked using an ethernet cable, and tested it using fast.com along with checking what I got on the speedtest app, it was registering between 530 and 570mb/s. A week later and it's no different. The engineer said the box I have in my house has a capability of receiving 2.5gbs and it is much more stable than the copper wire. So thing is, I'm paying for a 900mb/s speed on full fibre and I'm losing about 400 mb/s compared to losing 0 mb's when I was connected to the copper cable. This doesn't seem right.
Message posted on 06 Mar 2025 09:35 AM
Re: not getting guaranteed minimum speeds
@MD38 the guaranteed speed is to the hub and with full fibre you normally get what you pay for. I suspect the issue msybe simply that you have a black Sky hub which uses WiFi5 which tops out around 600Mb/s give or take. You need a WiFi6 router like the white Sky Max hub to get the full 900Mb/s over WiFi.You should of course get the full bandwidth over a gigabit ethernet link.
Given there are very few if any apps that can use 100Mb/s let alone 500Mb/s you may well decide you dont need to upgrade. Howevever if you do you will have to buy Sky's WiFi Max bundle that includes the white hub.
Message posted on 06 Mar 2025 09:42 AM
Thanks for the reply. Shouldn't they issue you with the latest hub if that's what I am paying for? Doesn't seem to explain the engineer's results of the slower speed though.
Message posted on 06 Mar 2025 09:50 AM
I wasn't told that I would get slower speeds if I remain with the black hub and that there was another type of hub that would give you faster speeds.
