Discussion topic: not connecting.
Message posted on 20 Jul 2026 07:14 PM
not connecting.
the wifi box is only showing 2 green lights. i have turned it off, reset it.. still the same. so we can't use anything in the house that is connected to the internet.
Message posted on 20 Jul 2026 07:45 PM
Re: not connecting.
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
