Discussion topic: nosy neighbour
This message was authored by: KFk
nosy neighbour
My neighbour is using my wifi. How can I disconnect devices that are not in my home?
Re: nosy neighbour
@KFk  You can change your Wi-Fi password using the link below.
https://www.sky.com/help/home/broadband/connecting-to-my-broadband/my-wi-fi-password/articles/find-a...
Re: nosy neighbour
@KFk  Your neighbour can only access your wifi if:
1) You or someone else has given them the password
2) They have obtained ot from your hub if it's on display near a window or if they have been in your property
If non of the above have occured it's impossible for them to just connect, however if you are concerned you can simply change the wifi password as explained by @Highlinder  reply.
