3
This discussion topic has been answered Discussion topic: no wifi
This message was authored by: tlbx
no wifi
2nd time this week my wifis been down, every single week theres an issue, i had a new hub a few months ago and that hasnt even made a difference, is it worth just changing company at this point? its broken more than its fixed lately
Re: no wifi
@tlbx
You have posted at 0144. Any broadband issues between midnight and 7am are likely to be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Re: no wifi
@tlbx
Avatar for tlbx
Re: no wifi
alright then i'll be swapping company's then, i need my internet at night time and no other company has this issue and it hasn't been an issue up to this point but now it doesn't serve me the purpose i need or am paying for so thank you
Re: no wifi
@tlbx
You do realise we are customers here on a customer ➡️ customer discussion forum where we try to help other Sky customers? I’m afraid you aren’t communicating with Sky by posting on here.
