Discussion topic: no wifi
Message posted on 17 Nov 2025 10:21 AM
no wifi
voice light is orange. no device will connect. app says all is ok. tried restarting everything to no avail.
Message posted on 17 Nov 2025 10:54 AM
Re: no wifi
@elartee
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
