Discussion topic: no internet connection
This message was authored by: ginodg
if i check in the apps its says wifi ng broadband good connection.but when i check the broadband orange light and no light in internet.
Re: no internet connection
@ginodg
@ginodg
Have you tried a reboot of your hub at the mains ?
If that doesn't fix it then try running the line test here:
If this is of no help give Sky a call to report it to them.
