Discussion topic: no broadband
This message was authored by: Kamran43
no broadband
No broadband, the small open reCh white box on wall has no lights on it
Re: no broadband
@Kamran43
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any potential Openreach visit.
Avatar for Kamran43
Level 0 icon
Broadband off
Is there not a telephone number to speak with broadband technical team for a remote fix over the phone
going in cirlces with online/app sode of things
Re: Broadband off
@Kamran43
No need for a separate thread. To call Sky dial 150 (free) from a Sky Talk landline or a Sky mobile or alternatively use the following link which will lead to contact details which will hopefully (but not necessarily guaranteed at the moment) include a phone number
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number.
The posting of full phone numbers isn’t permitted on the forum.
Any calls to Sky will initially be automated which may try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Alternative means of contact are:
(a) through the Sky Virtual Assistant on the same page - depending on your query, which can connect you with a live agent virtually if necessary or provide you with the contact number or
(b) via Skys social media sites (the links are at the bottom of this page).
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia.
