Discussion topic: my wifi has been poor for a long time
This message was authored by: HD
Message posted on 17 Jul 2024 10:38 AM
I have run the tests to check my wifi but it always says 'looks good'. i have to always 3come off wifi and use my mobile data instead as my wifi is constantly lagging
Can i switch provider? or am i under contract
Find out more
Message posted on 17 Jul 2024 11:01 AM
Re: my wifi has been poor for a long time
@HD Only you will know if you are under contract. If you go to the link below and sign in it should tell you when or if you are still in contract by the date
