Discussion topic: moving home
This message was authored by: Sh4nnen
moving home
Hello, can someone tell me how to change my address on my broadband? we are moving house in a few weeks and want to make sure wifi is set up and changed but when i put in my new address i got told to 'get in contact' but cant get through to anyone
Re: moving home
@Sh4nnen moving broadband is far more complicated than just changing the address. You need to go here https://www.sky.com/moving-home and start the process but do note the minimum lead time is 2 weeks to dort out a connection at your new address.
Re: moving home
@Sh4nnen
As @Chrisee indicates, broadband does not follow an ISP router around the national Openreach network, and has to be specifically commissioned at the new address which can have a considerable lead time.
'Get in contact' may mean that Sky cannot offer the same service at the location you are moving to as you have now.
Putting the address into the BT Wholesale Availability Checker should indicate the possible broadband types at that location.
This message was authored by: Parul1
Re: moving home
I'm moving home in the next month. How do I transfer my Wi-Fi to the next property which has? Talk talk
Re: moving home
@Parul1
You don't 'transfer WiFi'
If you wish Sky to remain your ISP (and particularly if you are currently within a minimum contract term) then you need to book a Home Move, through which Sky takes over the broadband circuit to the new address.
The current ISP there isn't significant unless it's unusual circumstances (such as TalkTalk using a CityFibre optical connection)
This message was authored by: ECH853
Re: moving home
I am literally moving next door and want to take my broadband/landline with me but I have to call them  - why can't I just do it on line?
Re: moving home
@ECH853  Here a link to do a home move.
https://www.sky.com/moving-home#ready-to-get-in-touch
