Discussion topic: lost connetctions
Message posted on 27 Jun 2026 03:25 PM
lost connetctions
system keeps dropping off and will only reconnect when I stand next to the hub , range of signal from hub is around 6ft from hub if further signal is intermittent.
Message posted on 27 Jun 2026 04:51 PM
Re: lost connetctions
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
