Discussion topic: line running through trees is that causing my issuses
Message posted on 24 May 2024 10:00 AM
Message posted on 28 May 2024 03:12 PM
Re: line running through trees is that causing my issuses
What issues are you having? Can you please post your router stats
Message posted on
28 May 2024
04:31 PM
- last edited:
29 May 2024
09:08 AM
by
Kelsingra
This page shows the current settings for your Sky Hub. We have preconfigured your Sky Hub with the optimum settings. This is a read only summary page. If you wish to change settings use the menus at the top of this page.
- Select Show Statistics to see your Sky Hub performance statistics such as the number of packets sent and number of packets received for each port.
- Select Connection Status to see information about your current connection.
(removed)
(removed)
(removed)
Pick a product for more help.
Sky Q
See more info
WiFi
Looks good
Sky Broadband
Looks good
36.5
36.5 megabits per secondMb/s
Last checked: 10 minutes ago
Sky Mobile
Check your coverage
Sky TV apps
Check apps
i have fttc and i have reset the router on sunday iv reset the network on my sky q box and updated the software ect but its showing all good with wifi ect on the app but thats what i get when i look online on the website may i ask why i cant see the info too please
any advice and help and if cant help may i ask to have it raised to sky please and help and advice will be very appreciated and grateful:) :
:d 😄
Moderator note: Removed personal/identifiable details
Message posted on 04 Jun 2024 11:44 AM
Your stats suggest there isn't a line problem so the line running through the tress is a non issue.
What exactly is the problem you are experiencing?
Message posted on 05 Jun 2024 08:09 AM
@jamesn123 i was getting low speed and high noise margin and openreach came out and increased my speed and im on a 40/10 but only getting 37.5 and he tested it but it came back ok but he said the fault might not be showing at that time and he said he contact sky to have the router replaced as he thinks its to fault but its only under 1 yrs old if need any more info i can give more 🙂 😄
Message posted on 06 Jun 2024 10:46 AM
I am confused, is 37.5mbps under your guaranteed minimum? If not then there is no fault.
Its completely normal to lose 5-10% of your sync speed when running a speedtest due to network overheads. So if your line speed is showing as 40/10 then a speedtest of anything above 37mbps down & 9mbps up would be considered normal.
Message posted on 06 Jun 2024 12:20 PM
@jamesn123hi im fftc and my minnium is 36.9 and yes i fully understand 😞 🙂
Message posted on 06 Jun 2024 12:22 PM
To be quite honest, looking at your lines margins, I dont see why you couldnt achieve more than 40mbps. Did you specifically go for the Superfast 35 package or are you on a Social Tariff? If not you should be able to get onto the 'Up to 80mbps' package.
Message posted on 06 Jun 2024 01:47 PM - last edited: 06 Jun 2024 02:03 PM
@jamesn123hi i went to fttc (superfast )before they brought out the superfast 35but they decided to put me on the superfast 35 as i went to (superfast in 2020) during lockdown so i had to tell openreach man that what was happing at router ectso not my choice to move to the (superfast35) and i had open reach out the other day and he brought my line speed to 40/10 but said that i can get about 50/60 but he said he cant do that ? as it could make my line unstable? and it would pull my speed down again to 40 but i cant see why i cant get them speeds but i post a wholesale pic so you can see my sppeds i could get
Threshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in Jumper High Low High Low VDSL Range A (Clean)
49 36.9 10 6 34.8 Unavailable Available -- VDSL Range B (Impacted)
48.1 34.5 9.9 5.3 27.4 Unavailable Available -- G.fast Range A (Clean)
-- -- -- -- -- Unavailable -- -- G.fast Range B (Impacted)
FTTP is not available.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Thank you for your interest
Message posted on 06 Jun 2024 01:51 PM
Ah looks like its because your handback threshold is below 40mbps so Sky will have put you in the lower speed bracket
Message posted on 06 Jun 2024 02:12 PM
@jamesn123 but im confused it says i could get 49 but im only geting 37.5 to hub
Everything looks good. Need more help? Pick a product.
Sky Q
Looks good
WiFi
Looks good
Sky Broadband
Looks good
37.5
37.5 megabits per secondMb/s
Last checked: 6 minutes ago
Last checked: 5th Jun 16:31
Super for streaming, gaming and downloading
Speed to your hub
Last checked: 3 seconds ago
Message posted on 06 Jun 2024 03:38 PM
@loverboi it is Sky's policy to provision customers whose lines have handback speeds under 40Mb/s onto the 40/10 Openreach product. This has been queried before but customers are not given the option of the 80/20 product even if in ideal circumstances their lines could achieve speeds on 40Mb/s down and 10Mb/s up. Other isps may have different policies. In practice the difference between 40Mb/s and 50Mb/s is going to be marginal.
Message posted on 06 Jun 2024 08:02 PM
@Chriseebut i feel sky are tring to take people for a fool as im on 40/10 but only getting 37.5 i feel thats a **bleep** take sorry for the bad words
Message posted on 06 Jun 2024 10:06 PM
@loverboi the sync speed of the hub is determined by its length and quality which is simply down to the laws of physics . A 40Mb/s sync will only give a speed test around 37Mb/s as you lose 8% to network overheads again a simple fact based on how networking works. So nobody is taking you for a fool.
Message posted on 06 Jun 2024 10:55 PM
@jamesn123okay thanks sorry for the rant but im 0.3 miles from the green cabnet but 0.5 miles from the exchange 🙂
