21 Sep 2023 04:45 PM
hi i need my router ip address and password it's not on my router
21 Sep 2023 04:55 PM
Posted by a Superuser, not a Sky employee. Find out moreDefault IP: 192.168.0.1
Username: admin
Password: Default WiFi password printed on the hub
Posted by a Superuser, not a Sky employee. Find out more@Lally If it's to login to your hube the user name is sky & password is either admin or the wifi password which is printed on the hub ;able, dependent on hub type
The iuser manual are here for each hub https://www.sky.com/help/home/broadband/sky-broadband-equipment/sky-hub/broadband-user-manuals/artic...
The default IP address of any model of Sky Hub is 192.168.0.1
The username is admin and the password is either sky or the WiFi key on the printed label on the rear of the unit.
21 Sep 2023 04:59 PM
there's no password on the back of my box i only want too set my cctv up and it needs too be 2.2 not 5g
21 Sep 2023 05:05 PM
Posted by a Superuser, not a Sky employee. Find out more@Lally As advised in previous posts the password is sky or your wifi pasword which will be printed on a label on the back of or underneath your hub.
It is dependent on which hub you have.
21 Sep 2023 05:06 PM
