Discussion topic: internet light off for about an hour
Message posted on 01 Jun 2026 02:35 PM
internet light off for about an hour, tried doing everything you guys recommend but nothing works
Message posted on 01 Jun 2026 02:38 PM
Re: internet light off for about an hour
@William149
Even if you’ve already tried it the first thing to do is use this link to check if there are any broadband outages or issues locally that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
