Discussion topic: intermittent drop in bandwidth
Message posted on 31 Mar 2024 02:25 PM
My connection speed over Wifi seems to fluctuate lots - sometimes going down to just a few Mbps and other times 14-16 but rarely anywhere near the 60 or so Mbps at the router (I tested it with an ethernet cable); thanks for any advice
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 47276267 93475166 0 18348 18512 136:59:13 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 91842311 46070277 0 367595 35273 00:10:13 WLAN (5 GHz) Up 3324145 1514218 0 4812 0 00:10:07
Message posted on 31 Mar 2024 02:30 PM
Re: intermittent drop in bandwidth
Is it just wifi devices or ethernet also . Wifi packed 10 minutes ago whilst everything else is 136 hours. It may indicate a fault with the router
@Joebug3 Going by the router stats it is showing the LAN as being down with no traffic having run through it at all.
You are getting 74.3mb/s down to the router and 20mb/s upload. Also notice that the 2.4 GHz frequency is used more than the 5.0GHz frequency. How many devices do you have on Wi-Fi?
Message posted on 31 Mar 2024 02:37 PM
@Highlinder @cookiemonsteruk up to 3-4 devices at any one time but not more than 2 streaming at once; sky broadband test says router speed is OK but nintendo has issues whether on ethernet or Wifi
