Discussion topic: intermet down
This message was authored by: Sean56
intermet down
Internet light has gone off entirely and phone has gone orange, power and Wi-Fi both green. Tried all 5 steps of sky self heal and cannot re-connect. Please advise.
Re: intermet down
@Sean56 There is not much can be done with the Internet off light, but try this link after an hour or so!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
And/or the following depending on your connection type below!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
